LeeJaeYoung
The frame goes underneath the wall.
Doors are standard here.
The window is something I simply made.
What command is this possible?
To study door frame creation, which gsm file should I open and study?
AC27 on window 11
1 Solution
Peter Baksa
the trick is that the wall contour is drawn again with simple LINE2 commands in "WallholeCut" macro.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Go to post
7 Replies 7
Does it really matter?
Will you see a difference when you print?
It is probably something to do with WALLHOLE2 and WALLLINE2.
But the Graphisoft objects are notoriously difficult to try to understand unless you are a GDL wizard.
Lingwisyer
Guru
If your object has all the AC window parameters, you could call the WallClosure macro into your 2D script. I think that will do most of the wall interactions for you.
LeeJaeYoung
While looking for the part you mentioned, I found and looked at the wallline2 part, and I could only see functions such as line_type and line_property in front of wallline2.
Next time I study windows and doors again, I will have to study them in more detail.
Thanks for your help.
AC27 on window 11
LeeJaeYoung
I asked this before, but there was no answer. ^^
I want the frame to be below wallline2. What shoul... - Page 2 - Graphisoft Community
AC27 on window 11
Lingwisyer
Guru
Time to merge threads.
LeeJaeYoung
The translation is strange?
AC27 on window 11
Peter Baksa
Péter Baksa
