GDL
SOLVED!
The frame goes underneath the wall.
LeeJaeYoung
Doors are standard here.
The window is something I simply made.
What command is this possible?
To study door frame creation, which gsm file should I open and study?
AC27 on window 11
1 ACCEPTED SOLUTION
Solution
Peter Baksa
the trick is that the wall contour is drawn again with simple LINE2 commands in "WallholeCut" macro.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
7 REPLIES 7
Does it really matter?
Will you see a difference when you print?
It is probably something to do with WALLHOLE2 and WALLLINE2.
But the Graphisoft objects are notoriously difficult to try to understand unless you are a GDL wizard.
Lingwisyer
Guru
If your object has all the AC window parameters, you could call the WallClosure macro into your 2D script. I think that will do most of the wall interactions for you.
While looking for the part you mentioned, I found and looked at the wallline2 part, and I could only see functions such as line_type and line_property in front of wallline2.
Next time I study windows and doors again, I will have to study them in more detail.
Thanks for your help.
AC27 on window 11
LeeJaeYoung
I asked this before, but there was no answer. ^^
I want the frame to be below wallline2. What shoul... - Page 2 - Graphisoft Community
AC27 on window 11
Lingwisyer
Guru
Time to merge threads.
The translation is strange?
AC27 on window 11
Solution
Peter Baksa
Péter Baksa
