ā2023-03-10 06:43 AM
When there is no gdl editor
When gdl editor is open
Why does this phenomenon appear?
The last line of gdl editor is not displayed.
It's something that happens on laptops...
Solved! Go to Solution.
ā2023-03-10 07:59 AM
Ahh, I see.
You mean the buttons for zoom, page orientation, scale, etc.
It could well be your screen resolution if you only have a small screen.
Ideally you want a resolution of 1920 x 1080 with 100% scaling.
ā2023-03-10 06:58 AM
You should see a horizontal scroll bar at the bottom of the script window.
If you are on a laptop, it may have something to do with the screen resolution.
Use the 'restore down' button to un-dock the script window and re-size it as you need.
ā2023-03-10 07:23 AM - edited ā2023-03-10 07:25 AM
RESTORE DOWN BUTTON NOT FOUND.
Wouldn't it be rude to ask for an explanation with an image? ^^
I work by sending the WINDOW task bar to the right and then to the bottom again. ^^
Is this question unanswered? ^^
I want to know the name of the parameter variable ... - Graphisoft Community
ā2023-03-10 07:48 AM
Sorry I forgot to attach an image.
It is the middle button that controls the sizes of you windows.
Make sure you do not click the bigger one above which is for Archicad itself.
ā2023-03-10 07:52 AM
In the floor plan, the bottom does not appear until GDL EDITOR is turned off.
ā2023-03-10 07:58 AM
This will make the lower part visible in the plan view.
However, if you go back, it is the same that the lower part of the gdl script is not visible.
Ahh, I see.
ā2023-03-10 08:01 AM
Is your script window undocked?
ā2023-03-10 08:07 AM
thank you
It was set to 125%.^^
