2025-11-17 02:46 PM
I updated to AC29 and library migration does not work.
Anyone else having this problem? on the otrher versions i could do it without any issues.
Operating system used: Mac Apple Silicon 15 Sequoia
Solved! Go to Solution.
2026-06-09 07:36 AM - edited 2026-06-09 07:40 AM
To highlight a point from a recent thread about this, if you were loading the Archicad Library 28 folder previously, you were using the Legacy Library and will need to go through the steps outlined in the Migrating to Archicad 28article to swap over to Library Packages, or continue using the legacy library, which is not included with AC29+.
If on the other hand you were already loading the individual libpacks within the Archicad Library Packages folder, then there is no "migration". The two sets of libpacks are mostly interchangable. There are a couple of AC29 only objects, but the rest libpacks will still load fine in AC28. There is also a stupid MVO change in the AC29 libpacks related to doors and windows that has not been resolved so I am still using the AC28 ones...
Ling.
