Installation & update
AC9 educational (student) version update
Greetings,
I have a problem with updating my student version of ArchiCAD 9. I have build #1954 and tried to install hotfix #2219. The installer cannot find the ArchiCAD file, even if I try to set the path manually. Is this my own problem, or is this because educational and commercial version are incompatible? How to update the educational version then?
I have AC12 as well, but I have some older projects in *.pne format of EDU AC9, which cannot be converted to *.pln. Sometimes I need to modify these old projects so I would like to have the latest version of AC9.
Thanks for advice and please excuse my English.
Windows XP
AC12 + Java RE 6 update 13
AC9 + Java RE 1.4.2_17
14 REPLIES 14
When the hotfix installation says that it cannot find your ArchiCAD file, can you manually browse to find the folder in which the file is located?
I think there is such an option in the install program.
Yes I tried to set the folder manually, but still the installer could not find any Archicad. I also tried to uninstall AC12 + JRE6 to prevent any problems vith versions (AC9 did not work with JRE6, only with JRE1.4.2) but it did not help.
Windows XP
AC12 EDU + Java RE 6 update 13
AC9 EDU + Java RE 1.4.2_17
Sorry, my Czech is not very good.
What does the message say?
Oh sorry, it says: There was not found any appropriate Archicad in this folder. Close this dialog, find another location, or click on Cancel and leave the installer.
now i have installed archicad12. after installation when i open can not open. it says vbutils.dll file was not found. please help any one. plsssss
palanikumar_pal@yahoo.co.in
