Apple MBP M2 MAX sucks.
Jimmy
my 2cents, hopefully this might save others time and money.
just bought a new mbp m2 max, it sucks, im returning it.
It doens't come close to my alienware x17r2 (i7 with rtx 3080 ti)
3d modeling is just terrible, where I spend a lot of time.
I didn't buy this machine for rendering.
27 REPLIES 27
Unabend
107305 and no problems with M1? Wow... šŸ™„
Ehm, sorry, what is SEO?
Unabend
Ah solid elements operations! Ok...
What kind of problems should it have?
Solid Element Operations
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
No way of knowing what you have done to your project.
For example:
If you have object A, seo object B which affects C, and that has BMat with object D and then you select all of them and do a SEO to a Mesh which then affects a roof… etc
Then AC will be going crazy evaluating all those steps.
  • If only a Mesh slows it down then check that you have no overlapping meshes.
  • If you use Slabs, Walls to SEO the meshes they might slow it down if you have too many of them and AC has to calculate how to clean Building Materials.
  • If you use a DWG as a reference and exploded it to then Magic Wand the lines to the mesh you might have Billions of nodes
  • etc.
AC29 US/INT -> AC08
another Moderator
Unabend
Ok thanks Eduardo
I think this may have been said before, if other files are OK, then there is obviously a problem with that particular file.
Do a little investigating on the file.
Take a copy so it doesn't matter if you destroy it.
Turn off (cancel) some/all SEOs.
Is it faster?
Delete a mesh.
Is it faster now?
Delete other elements of even delete entire layers.
Does it get faster?
Basically you need to trouble shoot to find what is the cause of the slow down.
Maybe then you can look at a different way to model those elements that will not cause a slowdown.
Only by investigation will you find the cause.
Or as Yoda would say "the cause by investigation you will find" 😁
We don't have the file so can only give general advise.
If you can, have someone test it on another machine.
If every file you open is slow, then you can complain about the machine.
Thanks Barry, replacing the mesh with a new mesh (with many points) its all ok.
You could also split the large mesh into several smaller meshes. This may create visible lines in 3D where they meet so you might want to do it along a terrain level line that is a visible line in the mesh anyway.
Another option is to convert the Mesh to a Morph, see if that gives better performance.
Another option is to convert the Mesh into a Library Part, see if that gives better performance.
Of course, these conversions should be done when you know the Mesh will not change much, otherwise you will have to redo the Library part save of modify the Morph each time there is a change i nthe terrain geometry.
