2025-09-18 08:52 AM
Does anyone have any issues to report? If CineRender crashing is the only issue, I'd like to upgrade.
Yes, I know the caveats, but would like to know what others may have experienced. Thanks!
2025-11-12 10:13 AM - edited 2025-11-12 10:14 AM
At least for me, this also happens with standard menus. I’ve edited the menus in Work Environment though.
2025-11-19 01:16 AM
Likewise!
2025-11-19 08:37 PM
I'm still investigating. I found some other unwanted behavior so reinstalled AC29. I also temporarily removed all 3rd party add-ons from 29 and 28. The bug hasn't recurred, but more testing to do.
2026-01-10 02:24 PM
I get that and I haven't upgraded to Tahoe.
2026-01-19 10:45 AM
this happens with Sequoia as well 😞
2026-01-19 02:11 PM
Issue identified and AFAIK working on a fix. It is not limited to AC29 nor current macOS.
See here:
https://community.graphisoft.com/t5/Installation-update/Drop-Down-Menu-UI/m-p/688983#M39158
another Moderator
2026-01-28 05:28 PM
Hi everyone,
This problem with the freezing menu windows is a known issue (DEF‑26526), and it is planned to be fixed in the next Archicad upgrade or hotfix.
As a temporary workaround, please note that the issue typically occurs when Archicad is not the active window, causing the menu bar to appear greyed out. In this state, please avoid clicking any menu items.
Instead, first click once inside the Archicad workspace (for example, on the floor plan or in the 3D view). In most cases, the menu bar will turn black again, indicating that Archicad is active. After that, menu commands can be used normally without triggering the problem.
In earlier cases, performing a full preference clean often resolved the issue, so it is worth trying this as well:
Preferences Cleaning with Preparatory Steps - Graphisoft Community
We’re very sorry for the inconvenience!
2026-02-13 09:37 PM
I had auto system updates turned off, and thought I was updating Sequoia.. but now I have Tahoe. I do use Cinerender a lot, so I am worried. I am on AC26. I opened a project, that had a rendering set up, and it generated fine. I have not messed with any settings however. Are there any know things that triggered the Cinerender crash??
Thanks
Tuesday - last edited Tuesday by Barry Kelly
Hi There, on macOS Tahoe 26 - 28.3.0;
2 ArchiCAD open,
> Search and activate works
> Other ArchiCAD programm empty window;
Is this fixed with 28.3.3 ? Works this with macOS Tahoe 26 ?....
I heard this failure is in ArchiCAD 29 too.... !!???
Wednesday
Hi, @Rex Maximilian , Thank you for posting this question because many of us who use Mac would like to know when it is safe to upgrade to Tahoe.
