ArchiCAD 28.3.0 & MacOS Tahoe
Does anyone have any issues to report? If CineRender crashing is the only issue, I'd like to upgrade.
Yes, I know the caveats, but would like to know what others may have experienced. Thanks!
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
19 Replies 19
vlahtinen
At least for me, this also happens with standard menus. I’ve edited the menus in Work Environment though.
JohnR
Likewise!
SeaGeoff
Ace
I'm still investigating. I found some other unwanted behavior so reinstalled AC29. I also temporarily removed all 3rd party add-ons from 29 and 28. The bug hasn't recurred, but more testing to do.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Bob Moore
I get that and I haven't upgraded to Tahoe.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
this happens with Sequoia as well 😞
Eduardo Rolon
Issue identified and AFAIK working on a fix. It is not limited to AC29 nor current macOS.
See here:
https://community.graphisoft.com/t5/Installation-update/Drop-Down-Menu-UI/m-p/688983#M39158
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Marton Batovszki
Hi everyone,
This problem with the freezing menu windows is a known issue (DEF‑26526), and it is planned to be fixed in the next Archicad upgrade or hotfix.
As a temporary workaround, please note that the issue typically occurs when Archicad is not the active window, causing the menu bar to appear greyed out. In this state, please avoid clicking any menu items.
Instead, first click once inside the Archicad workspace (for example, on the floor plan or in the 3D view). In most cases, the menu bar will turn black again, indicating that Archicad is active. After that, menu commands can be used normally without triggering the problem.
In earlier cases, performing a full preference clean often resolved the issue, so it is worth trying this as well:
Preferences Cleaning with Preparatory Steps - Graphisoft Community
We’re very sorry for the inconvenience!
Rick Thompson
I had auto system updates turned off, and thought I was updating Sequoia.. but now I have Tahoe. I do use Cinerender a lot, so I am worried.  I am on AC26. I opened a project, that had a rendering set up, and it generated fine. I have not messed with any settings however.  Are there any know things that triggered the Cinerender crash??
Thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Andreas81ch
Mentor
Hi There, on macOS Tahoe 26 - 28.3.0;
2 ArchiCAD open,
> Search and activate works
> Other ArchiCAD programm empty window;
Is this fixed with 28.3.3 ? Works this with macOS Tahoe 26 ?....
I heard this failure is in ArchiCAD 29 too.... !!???
ArchiCAD v6.5 - 30 (CHE Swiss Edition / Schweiz) - macOS / WIN - Workstation in office: mac OS 26.5.1, Apple M2 Max, 64 GB RAM
mthd
Hi, @Rex Maximilian , Thank you for posting this question because many of us who use Mac would like to know when it is safe to upgrade to Tahoe.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
