Archicad 20 performance drop
We are experiencing some serious 2D performance drop after switching from 19.
Already reported, but I want it to get some more attention as the problem is crucial and we have already switched some projects to 20.
Both machines are xeon w3565 with NVidia card (650GTX and quadro K620).
Project running smooth parallel in 19.
Drivers updated. GPU set to high performance.
Videos of the problem:
https://www.youtube.com/watch?v=wlj-qR6N1ZA
https://www.youtube.com/watch?v=By7CcTELfUw
Any suggestion would be good.
51 Replies 51
I am also having this issue on all machinies
Djordje
The OS is Windows 7
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello, i'm having the same issue.
Just to answer to Djordje, i had the same problem on windows 7, made the upgrade to 10 listenning to the call support, and no difference at all.
Hope they will correct this soon.
A+
Katalin Borszeki
Hi All,
We have done some preliminary investigation on this issue, and please help us out with some info:
From the logs we suspect that there are some special mouse driver settings where this occurs. Please check if in your environment this could be the case or not and get back to us in this thread! Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
I use razer gaming mouse (naga epic) and the orbweaver
We use Mad Catz RAT 9 and Kone XTD. Gaming macro mouses.
Other colleges with simple mouses are OK.
Working with tech support we discovered that when i change my polling rate to 500hz or below that the issue is minimal if even there.
Katalin Borszeki
Hi, thanks for all the immediate input!! We have entered this issue as a bug...while it is being corrected please use the following workarounds:
- adjust your mouse's sensitivity lower
- as mentioned in a previous post, set the polling rate to 500HZ
best
Katalin Borszeki
GRAPHISOFT
OK working with Steelseries driver if i lower the frenquency...
But not very convenient for me...
Hope you will correct if soon
Thank you
