vfrontiers
Archicad 27 Issues
So I have 2.5 MAJOR issues with 27...
  1. Files take an inordinate amount of time to open!  like 7 to 10 minutes!  Just a PLN... not tw'd
  2. Just tried my first PUBLISH...
    1. Seemed to cycle all the way down to the bottom of the list but got stuck on the last item...
    2. I went to the folder location where it was saving and watched it spike to 2.5GB pdf file and still growing when I force quit...
Can anyone verify?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
5 Replies 5
MinhNguyen
I had the first issue, even when starting a blank file - the startup screen was stuck for quite a while. I have a feeling it has something to do with the underlying new licensing method. I didn't bother to check however as I don't actively using it
BIM Manager - DKO Architecture - Archicad 28 on Windows 11
Robby
No such issue on my mac- other issues but not those....
Rob Marelli
AC 28.1
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.3.2
mthd
Yes with an older machine it can definitely take that amount of time for a project to load.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
PLMARCHITECT
I have two laptops, one older one brand new.  I have issues opening up files in 27 at the start menu.  They all hang, and I have to do a forced shutdown. I can only access them by going through the "browse for file".  Then the screen shuts down, I wait, and the file opens.
Botonis
Mentor
No problem so far. Files are loading and publishing as expected.
One idea is to check whether an addon is causing this lag.
