Archicad Movie player trouble
Movie Player does not emerge, if I liked to play.
Enlargement is possible.
Is it Bug?
5 Replies 5
I can only view the Movie Player in Maximize. If I press the Restore Down button the window will disappear. Tried Restore, Move and Size to no avail. I also installed the Movie Player hotfix as suggested but still have the same problem.
Which ArchiCAD version, guys?
Llian
I've posted the same problem. I have no problem with Chapter 01 to 05. I've downloaded the hotfixes as suggested.
Archicad 13
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
As a workaround, you can go to the folder into which the Guide was installed and double click the movie files to play them.
I still have the same problem, and cascading windows doesnt work either.
if you have an acer laptop then a work around is using the gridvista to grid windows.
Problem occured when I closed down archicad with the movie player minimised. I had no problem previously. Odd.
ArchiCAD 14.
Acer Aspire 6920G
