2017-10-07 12:36 AM
2017-10-07 07:25 AM
2017-10-07 11:11 AM
alemanda wrote:Thank you for replying but i only have these 4 options. Will any of these run the Archicad 20? And which one will run it faster IF they run it.. I don't know which one to pick
Go with ssd. This is a must.
The more ram is better. 8gb it's not a good amount.
15.6 would be my choice, no need for touch a screen.
Pay attention to graphics card. Should be not integrated.
2017-10-07 02:20 PM
2017-10-07 04:16 PM
Recommended video cards for laptopsBased on the above, you might want to reconsider the available options.
For reasons detailed above, we can not recommend any specific card and driver combination for laptops. However, there are professional video cards available for high-end laptops, such as the Nvidia Quadro, which are just as good as their desktop counterparts. We have also good experiences with most of the standard Nvidia cards, somewhat worse experience with AMD/ATI cards, and very bad experience with on-board intel graphic cards. Definitely avoid the latter.
2017-10-26 10:39 PM
ronni202 wrote:I would recommend a Dell Precision Workstation.
I'm trying to buy a laptop for archiCad 19-20. But i have low budget...
2017-10-29 06:05 AM
2017-10-29 10:43 PM
laszlonagy wrote:And be sure you check the dates on some of that info. What they need is a Benchmark file so people can post results based on the hardware people are actually using with ArchiCAD.
Make sure to read the recommendations of GRAPHISOFT:
https://helpcenter.graphisoft.com/technotes/setup/hardware-compatibility/recommended-hardware-for-gr...
2021-02-11 09:47 AM
juliadavid wrote:
I'm about to buy an ASUS ROG Zephyrus M GU502GW-AH76 Laptop with 240Hz display. Need your opinions guys!
Should I go for it?
2021-02-12 02:34 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
