ā2024-09-03
03:15 PM
ā2024-09-06
12:19 AM
I am getting "Archicad 27ā is damaged and canāt be opened. You should move it to the Trash" after installing the 27.2.2 Hotfix. What should I do to remedy this seemingly dire situation? Intuition tells me to reload the the original install and apply the Hotfix again. The only help the internet has provided for a solution less than that, seems a be questionable. Thanks
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
ā2024-09-04 12:03 AM
This happened to me and the only solution was to "uninstall" and reinstall.
another Moderator
another Moderator
ā2024-09-04 10:24 AM
Yep. Decided to go that route shortly after posting. I actually wasnāt as painful as I was expecting. Took care of the problem in short order. Thanks for responding though!
ā2024-09-09 02:09 PM - edited ā2024-10-08 03:29 PM
Thanks for the update.
ā2024-09-09 02:48 PM - edited ā2024-09-09 05:04 PM
Over the weekend, I installed the Ac27.3.0 INT Preview version update, and after installing the update and launching Archicad, no user interface appeared. Archicad loaded and I could see the Archicad window (I am under Windows 10), but only a gray background was shown, and no interface elements were displayed - no menu, no Floor Plan Window, no toolbars, nothing. I had to uninstall it. So, I just reinstalled Ac27 build 3001 for now.
Has anyone experienced something similar?
Anyway, I will report this to GS HQ.
ā2024-09-09 04:06 PM
I had the same problem. Reinstalled previous build too.
