HDES
Issues with dropdown menu after the last hotfix
I'm running a MacBook M3 OS Sequoia 15.6.1 and Archicad 28.3.1. I've been having an issue since downloading the last hotfix, where the dropdown menus won't go away after I use them. For example, I opened the file menu, and now I have the grey rectangle in the top left corner of my screen that I can't close. Is anyone else having this problem? Is there a solution? File size doesn't seem to matter. I've rebooted the computer several times, and it continues to happen.
14 Replies 14
It appears to be a Mac issue when you have an external monitor connected.
https://community.graphisoft.com/t5/Installation-update/ArchiCAD-29-Bug-empty-window-over-working-wi...
Is this your situation as well?
Do you have an external monitor?
Be sure to report this to your local support.
The more people that report this, the more likely it will be looked at.
Eduardo Rolon
Have had the issue without a Monitor connected.
Looks like it is a macOS issue only.
See here:
https://community.graphisoft.com/t5/Installation-update/Drop-Down-Menu-UI/m-p/686494#M39074
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Aaron Bourgoin
Pace Barry, I'm adding my name ot the list who experience this issue. Please fix it.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
Space_Agency
Same. On mac. No monitor connected.
Archicad V26 /V27 USA
MacBook Pro M1 Max
ram 64GB
Mac OS Sonoma 14.2.1
Space_Agency
Also, this just started after the latest hotfix. Very disruptive.
MacBook Pro M1 Max
ram 64GB
Hi, see my post here where at least I believe I have identified what triggers it for me. It may be different in your case, but hope this helps:
https://community.graphisoft.com/t5/Report-a-bug/Bug-with-ghost-menu-backgrounds-sticking-around-on-...
Roderick Anderson - CEO & Design Director - SARCO Architects Costa Rica
AC29 SPA - AC09
Macbook Pro M4 Max 64GB ram, OS X 26.2 Tahoe
SeaGeoff
Ace
There are now four topics at least partially devoted to this bug. Can the moderators please combine the comments. Thanks.
P.S. It’s been happening to me too, for over a month, and has persisted thru updates to both AC28 and AC29.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Glen_W
Yes I am getting the same problem on my mac and the only fix I can find is to restart archicad and eventually it comes back againanyway
Glen_W
Yes I have two monitors connected to a Studio mac
