2020-08-06 08:17 PM
2020-08-06 08:45 PM
2020-08-07 03:02 AM
2020-08-07 03:44 AM
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2020-08-11 01:15 AM
2020-08-11 01:18 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-11 01:48 PM
2020-09-13 03:30 AM
Karl wrote:
Your signature looks dated...so just checking:
Are you really using Windows 7 vs 10? if so, why?
If you are on a Mac, are you using Parallels or some other virtualization software to run ARCHICAD? If so, what and which version and which host operating system?
And, you're saying that 22 ran without the OpenGL warning before installing 23, and now it is 22 - not 23 - that is giving you that error message?
2020-09-13 03:52 PM
2022-06-28 08:05 PM
this is still happening.
The "Open GL" at times will just stop working in AC24 and in AC25. I've contacted Dell Support numerous times, they usually update the BIOS, update drivers, update etc....and this 'seems' to temporarily fix the issue but then after a day or so....it reverts back to the dreaded spinning blue ring.....then it appears the software is trying to update it's 3d tab and that's when it gets locked up.
I'm not quite sure just what's going on here with this "open GL" error I keep getting that doesn't allow me to navigate in 3d render mode where I was navigating just fine a few months back.
