Installation & update
archicad 25 Student licence no internet connection
Rutar Sofiia
Recently, I launched Archicad POL 25 with my educational licence and I could open files 30 days more, bbut I got a message "You are in offline mode - authorisation required" - this is my translation from Ukrainian. "SIGN IN" button is greyed out, so I can't sign in. I also cannot sign into my GS account from internet browser, because browser sends a connection error. Now I am writing from a different computer, because I have these problems only on my PC at home. It looks like it prevents me from logging into my Graphisoft account.
i have checked few solutions with hosts but they didn“t work
may someone have more solutions
Sefa Yakut
This problem is caused by not installing the License Manager Tool security update. Archicad 25 is currently not connected to the internet because the security update is not installed.
You can download and install the Security Update from the link here.
https://community.graphisoft.com/t5/Installation-update/Security-Update-for-Archicad-22-25-and-Licen...
4 REPLIES 4
Lingwisyer
Guru
Maybe check your internet routing, maybe you are routing through a region that is blocked by GS.
Also, I thought educational licences were only for the latest 3 versions of AC?
Sefa Yakut
Hi Sefa,
I just got home from work and finally had the chance to try what you suggested — and I can't thank you enough! Everything is working perfectly now. Installing the security update fixed the issue, and I'm so, so happy and relieved.
Seriously, I really appreciate your help. You made my day! 😊
Hello Sofiia,
I'm so glad you have no more problems, and thank you for getting back to me to let me know that the solution worked.
I wish you success in your work and your processes with Archicad.
Best regards,
Setup info provided by author
