Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
archicad movie player doesn't open
Llian
downloaded bpth collaboration packages 1 and 2 ...and having problem with the archicad movie player for COL-06.pln
Tried relaunch and doesn't work.
please help.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 REPLIES 4
hi
when i got problem with my movies player ... i normally used another player ...in this case KMplayer is the best ... it's free download it and test it !
hamed kassaei
hamedkassaei@gmail.com
TMA_80
Hi !
....Or try to run the movie outside archicad using quicktime !
AC12_27 |Win11_64bit|
Llian
i have no problem opening quicktime outside of archicad but just curious as to why it is not working within the Archicad/Help/Archicad Movie Player for Chapter 6 ? I have no problem opening it in Chapter 01-05 within Archicad environment. I've downloaded the hotfix and rebooted and still the relaunch can't work!
I would suggest that you report this problem to your local reseller.
I had a similar problem: I could not open the files belonging to Chapter 07 even outside of ArchiCAD. I don't know the cause, but it is strange.
Just to let you know you are not the only one with this problem.
