busera
Beginner
cannot read plan file Archicad 23
I was using Archicad 23, I had removed it from the laptop before. .bak file was giving an error I changed the .bak file extension to .pln file, it gives an error that the plan file cannot be read, what should I do now?
3 Replies 3
Read this helpful guide prepared by @mtron and edited by @Rubia Torres
https://community.graphisoft.com/t5/Project-Management-articles/File-Damage-or-Corruption-Troublesho...
AC 29 INT 4006/WIN 11
Guru
.bak? Not .bpn?
Are not .bak files only generated during the save process and removed after? If AC died mid save I would assume that the .bak file would be incomplete and hence most likely unreadable...
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
I agree with Lingwisyer, a BAK file is not an Archicad Project Backup, you need to look for a file with the same name as your project and having the BPN extension.
