lejlabakiu
graphic card not used 100%
i have a laptop with these configuartions:
processor: i7-11800h
graphic card: RTX 3070
ram: 16 GB
ssd m2: 500gb
but when i work on archicad does not go well while my friend with lower performance of laptop works  better than mine, is there any tips that can do with the settings or window settings for archicad to work better ? thanks for your time
Operating system used: Windows 10 22H2
What laptop?
Is it muxed or a muxless system?
That makes a huge difference in performance.
If it's a gaming laptop you may be able to turn off the dedicated graphics and only run the 3070.
If it's a muxed laptop you probably won't be able to do so but you can still likely change settings to always try to favor the NVIDIA GPU.
Lingwisyer
Guru
What's your RAM usage like? How much free harddrive space do you have?
