2 weeks ago
@Graphisoft:
Are there any experiences and test results about Archicad (27 + 28) is performing on macOS 15 Sequoia? (currently beta status)?
Thanks.
Regards
Roman
Operating system used: Mac Apple Silicon 15 Sequoia
Solved! Go to Solution.
yesterday
Hi there,
At the moment, we're not aware of any critical issues in Archicad on macOS 15. However, please note that we're still in the process of testing both Archicad and BIMcloud, and there will be more OS updates until the official release, so this may change in the future.
You can find an article with the latest news about the compatibility and known issues on macOS 15 here.
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2 weeks ago - last edited 2 weeks ago
I’d be interested in knowing this too. I used to run the Betas of both Archicad and macOS to test but Apple changed the virtualisation so I couldn’t install a VM. Apparently this all changes after Sequoia so I’ll be able to test the next versions.
a week ago
How will it change?
a week ago - last edited a week ago
Apple have updated their virtualisation SDK so after Sequoia you will be able to run any future macOS system within Parallels. At the moment it has to be the same os as the macOS on which Parallels is installed. You will be able to run the next major release after Sequoia within Parallels whilst still running Sequoia as your main OS.
a week ago
That is Great! or I mean That is Brilliant ...
yesterday
Hi there,
Kind regards,
Oleksandra
Oleksandra Vakariuk
