Llian
As a result of last operation...
I saved and replaced an object. I tried to place it on plan and this pops up…I can't place the object. What is this?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 Solution
Guru
Check the object's home story. It is set to above or below your current story. If you have gravity on, it might be snapping to the story of an object that is set to show above / below.
Ling.
Go to post
4 Replies 4
Guru
Ling.
Llian
Thanks. I found it is on another storey. How did it happen to be on another storey?
Guru
Not sure... I have had it happen a couple of times where the home story is set to something other than the current when placing...
Ling.
Llian
Thanks. This is something to look out for in future for placing object….🙂
