As a result of last operation...
Llian
I saved and replaced an object. I tried to place it on plan and this pops up…I can't place the object. What is this?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Guru
Check the object's home story. It is set to above or below your current story. If you have gravity on, it might be snapping to the story of an object that is set to show above / below.
Ling.
4 REPLIES 4
Guru
Ling.
Llian
Thanks. I found it is on another storey. How did it happen to be on another storey?
Lilian Seow
Guru
Not sure... I have had it happen a couple of times where the home story is set to something other than the current when placing...
Ling.
Llian
Thanks. This is something to look out for in future for placing object….🙂
Lilian Seow
