‎2025-03-08
12:22 PM
‎2025-03-09
01:49 PM
I have problems while importing 3ds model into Archicad 28, in Archive > Interoperability > there's no "import 3ds..."
I already installed Goodies Library
I already checked into Add Ons Menù, and 3D studio import is flagged
I already moved into "Menù"
In your opinion, which is the problem? What can I do?
Thank you all in advance
‎2025-03-09 02:01 PM
According to your Work Environment, it is in the Opzioni > Barra Menu and not Archive > Interoperability.
‎2025-03-10 02:19 AM
You can always just select it in the Add-on Manager and it will tell you where it is in your interface.
Ling.
‎2025-03-10
09:14 AM
‎2025-03-10
12:55 PM
Thanks for your feedback Berry,
but the problems is exactly that I can't see this option.
‎2025-03-10 09:19 AM
Yes and the Add On library is already charged on archicad, but still I can't see it.
i don't undestand the reason why.
‎2025-03-10 10:26 AM
It is not under file/interoperability but under design/designextras...
‎2025-03-10 12:56 PM
And, if you cannot find the commands anywhere in the menu, you can add them manually in the Work Environment Dialog.
