Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Cannot use objects in goodies 27 (roof accesory object)
MelisEkincik
I have tried all the latest suggestions to use roof accessories: I uninstalled archicad 27  then I reinstalled it. Before starting archicad, I Installed goodies 27. Started archicad 27. Although the design extra tab/accessories/roof accessories appear correctly  on the design menu,  the roof accessory object is not loaded.
Lingwisyer
Guru
This is the wrong place to be posting this issue. This forum is for threads related to the AC28 tech preview.... Thanks Barry.
Regarding your issue, have you loaded the Accessories Library 27?
Ling.
Yes, I have all these libraries but unfortunately I still can't use the roof accessory.
You don't have the Accessories library loaded.
It is a separate library in the Archicad program folder.
