2020-05-19
08:29 AM
2023-05-23
04:06 PM
Rubia Torres
2020-05-26 11:47 AM
2020-05-26 01:14 PM
2020-05-26 01:25 PM
2020-05-26 01:30 PM
2020-05-27 10:59 AM
Barry wrote:I tried this method and got this output.
Roopa wrote:
Now I need to edit that model. I converted into morph. I need to open the mouth of the animal from that we have a step. How to do that??
That is the bit you will find is rather difficult.
Archicad is really not very good at this sort of modelling.
I would split the head so you have a top and bottom jaw.
Then split vertically where you want the bottom jaw to pivot.
You might want to place a temporary roof/slab/wall to get the cutting plane easily.
Now I would rotate the bottom jaw down.
Now the hard bit will be adding surfaces to join up the gaps.
Then union all the pieces back into one morph.
Add slabs,beams to form the passage you need and then SEO that from the morph.
I am sure it is much easier said than done.
2020-05-27 11:38 AM
Roopa wrote:
I need to show the mouth face open as the shape. How to do that?
Roopa wrote:
I created the morph seperatly and changed the building material which has greater priority then that. And tuned off the layer, its not coming....
How to do that?
2020-05-27 11:40 AM
2020-05-27 12:11 PM
2020-05-27 12:26 PM
Braza wrote:How did you do this?
Hi Roopa A,
Here is my try... I hope your client haven't specified a "Service Exit".![]()
2020-05-27 01:03 PM
