Door Pocket Void Fill - D1 Pocket 19
Tincan561
I am new to Archicad and setting up my first project with pen settings suggested by Shoegnome (thank you.) Please forgive any basic questions.
I am unable to determine which parameter controls the fill for the pocket door void in a wall. It seems to be controlled by pen #91, which I have made yellow in the attached image.
My other settings for the doors, composite wall materials and the wall element itself seem fine. I can't find pen #91 anywhere in those settings. Can someone tell me how to turn off the fill in the pocket void?
One other question: Is it possible to change the global color used in the MVO > Override Cut Fills > Solid Foreground? I would like to use a color other than dark gray.
Archicad 26 Macbook Pro, Ventura 13.6.3
5 REPLIES 5
Stress Co_
Look for "Pocket Fill Background Pen" in the "All Parameters" tab.
(Note: my screen shot is from AC18)
Marc Corney, Architect
Red Canoe Architecture, P. A.
David Maudlin
From the Help files (User Interface Reference > Dialog Boxes > Model View Options Override Fill Display):
Override Cut Fills: Check this box to override cut fill definitions. Choose one of these two options to define the display of all cut fills in the project.
• No Fill: Cut fills will not be displayed, except for their contour lines.
• Solid Foreground: Each cut fill will be shown in a single solid color, the one set for its cut fill pen in its element settings.
• Show Skin Separator Lines: Check this box to display separator lines of composite elements.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Tincan561
Thank you both for your reply; however I need further assistance.
Stress Co: I cannot find any parameters for Pocket Symbol Fill for AC19 D Pocket 19. Perhaps someone using v19 can help me?
David Maudlin
Tincan561 wrote:
Since cut fills are determined by Building Materials, then this "global' override should take on the pen color of the building material used by the composite elements, which is not the case.
It works here: the color is controlled by the Building Material's Cut Fill Foreground Pen (see attached image).
Tincan561 wrote:
Even when I override the cut fill of an individual composite wall element, to red for example, it too turns dark gray when I do a 'global' override. Can you provide a more detailed explanation on how to control this color? [/img]
In the Wall Settings dialog box > Floor Plan and Section > Cut Surfaces > Override Cut Fill Pens: change to Foreground, then change the Cut Fill Foreground Pen to the pen color you want to use.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Tincan561,
Thank you for pointing this out. It appears to be a bug in the UI. I will report it to our Library team to fix it in an update. In the meantime, here is a video of a temporary workaround you may use:
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
