2015-10-04
01:27 AM
2023-05-24
10:48 AM
Rubia Torres
2015-10-04 08:34 AM
2015-10-04 02:05 PM
Tincan561 wrote:From the Help files (User Interface Reference > Dialog Boxes > Model View Options Override Fill Display):
One other question: Is it possible to change the global color used in the MVO > Override Cut Fills > Solid Foreground? I would like to use a color other than dark gray.
2015-10-05 02:30 AM
2015-10-05 03:59 PM
Tincan561 wrote:It works here: the color is controlled by the Building Material's Cut Fill Foreground Pen (see attached image).
Since cut fills are determined by Building Materials, then this "global' override should take on the pen color of the building material used by the composite elements, which is not the case.
Tincan561 wrote:In the Wall Settings dialog box > Floor Plan and Section > Cut Surfaces > Override Cut Fill Pens: change to Foreground, then change the Cut Fill Foreground Pen to the pen color you want to use.
Even when I override the cut fill of an individual composite wall element, to red for example, it too turns dark gray when I do a 'global' override. Can you provide a more detailed explanation on how to control this color? [/img]
2015-10-05 10:38 PM
