2018-01-30 03:49 PM
2018-01-30 04:50 PM
2018-01-30 05:29 PM
2018-01-30 05:46 PM - edited 2022-02-18 05:25 PM
Yes, OK, so I did misunderstand what "horizontal railing spacing" means.
No, you cannot set a fix distance between horizontal Rails.
What I would do is I would use the "Profiled Rail 21" Rail GDL Object, which can use Profiles created in the Profile Manager.
Then in the Profile Manager I would draw the number of Rail profiles at the desired spacing and use that.
2019-07-15 03:22 PM
2020-07-20 09:38 PM
ponaelius wrote:Can only agree this is a major oversight. I've been messing for the last couple of hours thinking I must be missing something obvious only to come and read this.
I'd hoped this was not the case but I came to the same solution as you Laszlo.
Surely there should be the option of horizontal balusters that behave the same as the vertical balusters, the current workflow is very inefficient.
2020-07-22 03:07 PM
2020-07-22 06:37 PM
2020-07-22 10:10 PM
				2020-07-22 11:01 PM
