2023-10-30 12:35 AM - edited 2023-10-30 12:47 AM
There's a bunch of ways to clean up/create Objects in Archicad. Here's a link to my recent blog post and YouTube video showing how to take a SketchUp object, explode it into a morph, clean it up, and turn it into a Archicad object with a good 2D symbol:
And here's a link to the YouTube video itself, if you want to skip the additional info in the blog post:
https://youtu.be/cU4gNFADZm8?si=5xK0plk9EkhF0sSY
2023-10-31 08:26 AM
DreamHost is supplying free certificates via Let's Encrypt. You just need to go through the process and add it to your domain. A quick search presents an article from DreamHost about how to do it.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-10-31 09:56 AM
@JaredBanks Back to your OP, you could also combine everything you have shown with the Library Part Maker add-on to generate objects with MVO controlled detail if that was relevant to the SU model and user requirements.
2023-10-31 09:59 PM - edited 2023-10-31 10:09 PM
I haven't looked at LPM in way too long. I'm looking forward to hearing James Murray talk about it this afternoon during his Archicad by the Beach presentation. We had a presentation on Modelport 3.0 yesterday and that looks really promising for similar import needs.
2023-11-06 10:34 PM
Karl, Thanks for pointing this out. It was the kick in the <redacted> that I needed. I got the SSL certificate all set up this morning. Everything should load properly for you now.
