Kori
Missing surface image that's not listed in Surface Attribute
We're currently in the works to upgrade our templates from AC27 to AC29.
Which is always a good time to clear out any warnings from the library manager, but this one I'm getting is vexing me.
As an example:
Under Missing Library Parts > from Attributes I'm missing:
When checking for more info, I see it is missing from the following attribute:
So, next I check that surface in the surface manager, but wierdly enough, there's nothing listed as missing there. See image below for the settings of that surface:
I'm at a loss how to proceed fixing the error message from the Library manager.
Any help?
XS Architecten U.A.
https://www.xsarch.nl/
AC29 NL Perpetual - Windows 11
1 Solution
David Maudlin
Kori:
In the Surfaces dialog box, also check the settings for the Cineware engine, it could be used there.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
4 Replies 4
cuba
It may be that a texture is being used elsewhere as a texture. Open the Attribute Manager to find the missing textures; these are indicated with a red icon.
Groeten!
Apple M1 Max 32 GB
Latest AC
David Maudlin
Kori:
Kori
Thanks David,
This helped me out.
The exact solution (in case others encounter the same issue) was to go to:
Cineware Engine > Match settings >  Update Cineware Settings (from Basic).
Issue resolved.
Also, thanks for the tip on the signature (should be fixed now).
XS Architecten U.A.
David Maudlin
Kori:
Good to know that worked.
Using the Update Cineware Settings (from Basic) command is one way, but it will simplify the Cineware settings. Not a big deal if the Cineware engine is not being used:
Otherwise, one has to search in the Cineware settings to find and replace the missing texture.
Thanks for adding your signature.
