Need to find the This JPG file that is in my template
Eric Milberger
Need to find the "concrete blocks - Stack Bond cb -opt.jpg" that is in the current template
I need this as a template for other work and building of a similar library with different colors.
Where Can I get this jpg file - Please and thank-you
Eric Milberger, Architect | Master Planner
1 REPLY 1
Ricardo Lopez
Hi @Eric Milberger
Yoy can find that .jpg in File> Libraries and Objects> Library Manager... inside the default Archicad Library 27> Surface Catalog 27.lcf> TImg. Textures 27> Concrete 27
You can select it and Export
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Setup info provided by author
