No Sink and can' see what I have
I cannot find a wall mounted porcelain sink in v27
I have foudn a sink but it is not typical and cannot be adjusted.
I also cannot change its settings as it only shows as a ghost on the plan and I have set all items i can find in the file to black.
The sinks are next to the toilets  and it is barely showing like a ghost element
Eric Milberger, Architect | Master Planner
cuba
It is very hard to understand what your mean to say;  What kind of sink do you want and what kind are you using at the moment?  Is it on the correct story & height?  Please add more info.
Apple M1 Max 32 GB Ventura
AC27
Guru
If the objects are not password protected, you could open the script and just add a "PEN 1" or what ever your desired pen is to the start of the 2D script, or replace any existing PEN commands if they exist.
Ling.
Setup info provided by author
