Eric Milberger
No Sink and can' see what I have
I cannot find a wall mounted porcelain sink in v27
I have foudn a sink but it is not typical and cannot be adjusted.
I also cannot change its settings as it only shows as a ghost on the plan and I have set all items i can find in the file to black.
The sinks are next to the toilets  and it is barely showing like a ghost element
Eric Milberger, Architect | Master Planner
2 Replies 2
cuba
It is very hard to understand what your mean to say;  What kind of sink do you want and what kind are you using at the moment?  Is it on the correct story & height?  Please add more info.
Apple M1 Max 32 GB
Latest AC
Guru
If the objects are not password protected, you could open the script and just add a "PEN 1" or what ever your desired pen is to the start of the 2D script, or replace any existing PEN commands if they exist.
Ling.
