STRUCTURAL ENGINEER'S OBJECTS
Takis
Structural Engineers need special 2D & 3D library objects inside Archicad.
27 REPLIES 27
Takis
I tried to upload them but it was asking for an .lcf file and I didn't know how to proceed so I gave it up - could you guide me how to upload them somehow?
Check out these two Knowledge Base pages:
https://community.graphisoft.com/t5/Libraries-objects/How-to-use-BIM-Components/ta-p/303460
https://community.graphisoft.com/t5/Libraries-objects/BIMcomponents-Frequently-Asked-Questions/ta-p/...
Takis
Single and Double Spring Isolator objects already uploaded to BIM Components.
Laszlo thanks for the help.
Takis
Unfortunately there is something wrong with the 3D script of the spring isolator objects and cannot be uploaded to BIM Components until the problem is fixed.
Both objects work fine, so you may download them from here.
Takis
Hey All, this is more about a wish but I am sending it here to continue discussion.
The subject is a 2D reinforcement palette tool the same they use Autocad Users. The 2D reinforcement tool palette is work effective and quick with structural details and calculations.
For a start, I would like to see a similar tool in Archicad 19.
Takis,
Have you see the Eptar reinforcement tool (http://www.eptar.hu/cadsupport.php?id=product_block&pID=9) it seems to do what you are asking but in 3d. At approx 400 euro seems to be priced similarly to Revit add ons.
Scott
Takis
Scott hi, yes I've tried that.
Well it is too difficult and time consuming to try to use 3D for 2D detailing purposes and furthermore it is almost impossible to show the exact detailing of the reinforcement.
Takis
Hi to everyone, I would like to share a 24m height communication Tower object for a project I completed about a month ago.
No special detailing in Archicad, you may use it for presentation purposes.
Makes quite good renderings in Artlantis.
Takis.
