Stairs - Model View Options - Riser / Tread text
Michael James Lucas
Does anyone know if it is possible to to turn off the riser / tread text on stairs in the model view options (or any other way)? I'm trying to make clean presentation floor plans.
I could of course select all stairs in 3D and deselect the text, but that seems to be a work around.
AC6,5 - AC24
6 REPLIES 6
Erwin Edel
You can set up scale sensitivity, but there are no modelview related settings.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
That is for Stairmaker stairs, though. The other stair objects have different settings most of the time.
www.leloup.nl
Windows 10 Pro
Michael James Lucas
Unfortunately there's no option to make the text react to scale, so that won't work.
AC6,5 - AC24
Erwin Edel
You could use a 3D document floorplan for presentation, maybe. That won't show the 2D scripted stair.
www.leloup.nl
Windows 10 Pro
This was always a problem.
Workaround is to use a pen for this text which is white in a presentation penset and any other color for working penset.
Michael James Lucas
Thanks Philips, hadn't thought of that one!
AC6,5 - AC24
