Tracker - Coordinate problems
ngoldie
I'm having trouble with the tracker - it shows the distance for slabs as the distance from project zero and after I do the first click then it shows the distance from the last point. It doesn't have this problem with walls though....
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
Can you attach 2 screenshots?
One showing what the Tracker displays after the first click during Slab creation.
One showing what the Tracker displays after the first click during Wall creation.
The screenshot should also show which Geometry Method is being used for each.
ngoldie
I seemed to have worked it out - I just copied across my settings from a previous job onto the new job for the coordinates (I still have no idea what setting was set differently).
I appreciate your time.
Thanks,
Naomi
Archicad 20
