2010-01-18
11:34 AM
2023-05-24
11:55 AM
Rubia Torres
2010-08-05 09:19 PM
2010-08-06 05:28 AM
Kevin wrote:No, I just tried to copy from the GS objects (doors and windows are way too complicated to follow!) and from the GDL referenece guide.
Do you have a source that could shed some light? I am also not understanding the GDL reference guide either.
Kevin wrote:As far as I can see from the standard GS library the door swings are controlled by with the macro "RequestDWGlobals"
At this point I am not interested in creating a new tab in the MVO. I would just like to take advantage of the existing tab, either in AC 13 or 14. What are the parameter names that should be used? Is the parameter in the command (middle value) the parameter name of the libraryglobal or the script I creates parameter? What about the value (third value)?
My goal is to switch the door/window swings on my office created doors/windows to be controlled by the out of the box MVO. I am struggling where to obtain enough information to help this newbie gain some insight.
Kevin
2010-08-06 12:23 PM
No, I just tried to copy from the GS objects (doors and windows are way too complicated to follow!) and from the GDL referenece guide.Thank you for saying this. I thought that was only my perspective.
2010-08-06 09:15 PM
success = LIBRARYGLOBAL ("LibraryGlobals13", "D_showBOpLine3D", bOplinesTemp)
if success > 0 and bOplinesTemp <> 0 then
bOplines = bOplinesTemp
reqOplinePen = 1
success = LIBRARYGLOBAL ("LibraryGlobals13", "D_opLinePen", reqOplinePen)
if success > 0 then
gs_opLinePen= reqOplinePen
endif
endif
I have been unable to get beyond this point.2010-08-09 08:11 AM
Kevin wrote:I'm not sure what is happening there.
Barry,
This communicates an error stating that the second line is uninitialized.
success = LIBRARYGLOBAL ("LibraryGlobals13", "D_showBOpLine3D", bOplinesTemp) if success > 0 and bOplinesTemp <> 0 then bOplines = bOplinesTemp reqOplinePen = 1 success = LIBRARYGLOBAL ("LibraryGlobals13", "D_opLinePen", reqOplinePen) if success > 0 then gs_opLinePen= reqOplinePen endif endifI have been unable to get beyond this point.
Kevin
