Patrick M
loaded libraries, missing library parts
we have updated our template to the .libpacks... a kid at the firm saved a .pln to his desktop, worked on it over the weekend, and uploaded it to the server this morning.
all library packs are loaded to the library manager, but content from the local version of them to the server version does not translate through. anything I'm missing?
(I swear these library packs have been nothing but trouble. I love that we have the INT doors and windows now, but it hardly seems worth it for all the headaches this 'transition' has caused!)
flat skylight placed in pln, missing in teamwork file
flat skylight is definitely in the loaded libraries
library manager example: objects missing from Plumbing fixtures and bathroom.libpack - plumbing fixtures and bathroom.libpack is in the library manager and not reporting 0mb.
 I also verified this was not a one off local data corruption. The designer who reported this, I had him clear his local data and re-join. I joined the file, and see an identical set of missing library parts.
6 Replies 6
Charlie64
This has happened to me when i open old pln (say pln from archicad 28) when i'm using archicad 29. Is it possible that someone is using older version? Or maybe different license (non-comercial...)?
It's been 2 weeks and I'm sure the file is gone and you're on to other things, Patrick.
My thought on tracking down this bizarre behavior is to check the UID of the placed objects that report as 'missing'... my hunch is that a library update might have been applied which changed the UID, and even though it should match by name if the UID can't be found in the loaded libraries (at least from what I recall) - it obviously isn't doing that.
Here is a screenshot of a placed "Skylight Flat Panel" from the latest library update, with the Element Info palette showing the Unique ID for that skylight object.  After that, is a screenshot of the same file, after saving with all libraries purged, and the "dot" representing the missing skylight selected...and the Element Info palette showing that, as expected, the UID of the placed object, missing or not, is the same.  I'd be curious what the UID is in the staff member's PLN vs as you see it after re-joining and placing the same-named object from your loaded library, although at this late date, it's probably impossible to do that unless you archived those files...
Make sure that everyone has the same library pack updates.
I am not sure how this works with BIMcloud as I don't use it.
There was an issue early in 28 where the library packs were updated.
If someone using the file with library update two saved a file and someone with only library update one opened the file, objects would be missing.
I think this was mainly doors and windows but may affect other objects.
See.. https://community.graphisoft.com/t5/Libraries-objects/Library-Parts-appear-as-quot-Missing-quot-even...
Lingwisyer
Guru
The file is set to read the libraries from the BIMCloud, so it should be consistent between users.
On the same note, if the migrated file was done offline using updated local libraries then uploaded without also updating the online libraries I guess you could run into the same issue? Not sure if it checks, or if you have to manually update the BIMCloud libraries. If it is missing for all users, I would say that this is the case.
Ling.
Patrick M
Ling, that could be. I am a bit out of the loop on that user's process. I know he was working on a pln saved from the bimcloud; I would have assumed he would have retained the bimcloud library connection, but maybe he gutted his library manager in the process...
in any case; if the library part with that name was placed, and that library part with that name exists in the loaded libraries; it SHOULD work...
it's another in a long list of "you need to be a programmer level expert to use this software or its going to break on you". I was able to relink all his missing parts, but the reason they went missing is lost somewhere in his workflow. If it's due to differences in his local libraries and the server libraries, but both libraries contain the same library parts, then this is definitely a deficiency in the software that should be resolved.
Lingwisyer
Guru
Yeah, the whole global library rollout has been a bit kacked...
