Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Licence Manager Sign In
Lingwisyer
Guru
When trying to sign into the Graphisoft Licence Manager Tool I get a message saying that it does not support MFA. Is this actually a thing, a major shortcoming?
Also, is there a way to stay signed in? Not being able minimise or close the tool to the task bar, and hence subsiquently needing to re-sign in later if you do not want the tool being an active window, is causing issues. Why do you even need to be signed in to upload your licence...?
Gradually getting more annoyed that our reseller will not supply hardware keys...
Ling.
Lingwisyer
Guru
MFA... guess I'm remoting to use a hardware key since I cannot login to the license manager.... What's the point of having MFA when it does not work with your licensing software...
Lingwisyer
Guru
Hm. SaaS works with MFA, so I guess they are not bothering to update the License Manager in order to push subscription...
