2006-11-15 06:12 PM - last edited on 2023-05-25 06:22 PM by Rubia Torres
2006-11-15 07:22 PM
2006-11-15 09:02 PM
2006-12-02 08:11 PM
Dwight wrote:How do you this? I'm having the same problem... can't find where to alter it. Cheers...!
The slab is made from a composite material with a determined thickness.
Switch the slab section fill material to a tone or other non-composite.
2006-12-02 09:04 PM
2006-12-02 09:55 PM
2006-12-02 09:59 PM
2006-12-02 11:10 PM
Dwight wrote:
Okay. "Composite structures" applied to roofs, walls and slabs have a fill corresponding to a predetermined assembly thickness.
Select anything else for a fill and you can change the thickness.
2006-12-02 11:28 PM
2007-03-04 06:34 PM
