ARCHICAD 22 INT version now available for download
It can now be downloaded from the following web page:
http://www.graphisoft.com/downloads/
Other localized versions will be coming soon.
23 Replies 23
insideru
The merge walls bug is still present in b3004 (didnt have the time to reinstall to 3006). Merge 2 composite walls and they will change position in plan and switch to profiled wall.
ARCHICAD 28 INT
macOS Sequoia
James wrote:
The wall trim issue should be fixed in the next update.
But there should be a more offical word on it soon
It would be great to know what the "wall trim issue" is, along with any known workarounds until this gets fixed.
Richard
AC26 (since AC6.0), Win10
James B
Hi Richard. The problem is when using cmd+click to trim a wall (between other intersecting walls), it doesn't always trim to the reference lines, but instead often to the wall face instead. Workaround to cmd+click on the intersection walls reference line to trim.
James Badcock
Thanks, James. Fortunately, that one doesn't seem to be a huge issue, but it's good to know the workaround.
Richard
Ernest Atanasiu
I think the wall trim issue is still there even in 3006. I just re-installed and I can't make it to work even with the workaround.
However I noticed that it's kinda erratic, sometimes it works and sometimes not.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
insideru
James wrote:
3006 fixes the automatic dimensioning issue. The wall trim issue should be fixed in the next update.
3006 fixed something else. wall trim next time.
ARCHICAD 28 INT
macOS Sequoia
Jere
I'm using the US version. Does anyone know where to go to download the additional surface catalog? The link in the ArchiPlus site sends me to ArchiCAD 19 catalog.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Yeah, the US ARCHIPLUS site is out of date, and actually kind of pitiful for what it offers.
But, the official way of getting the additional surface catalog is from within the product itself, and does lead to the AC 22 download page. See screenshot. From the New Surface dialog, click the globe button and then "Additional Surface Catalog for SSA users..."
Richard wrote:
nice screen display in 4K with display rescaling. It's a pleasure to work in.
Don't know on 4K, but in my case, I find it looks crappier on both my MacPro with QHD display and my MacBook Pro, while the "Don't smoothen horizontal and vertical lines" check didn't have any effect.
And just to clarify, they remain smooth in any case. Only disabling 2D antialias at all, vertical and horizontal lines become clear, but in this case the oblique lines become serrated.
