Align 3D texture
Tom Krowka
Will this command work with open GL engine setting. I can only get it to become active if I use the internal 3d option. The vectorial hatching has to be turned on (according to the help ); it is greyed out in the open GL setting.
When I marquee an area and go to the 3d window with the internal 3d engine on, only a small portion of the marquee area shows up.
Any suggestions?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
13 REPLIES 13
Dwight
Sometimes when you change the proportion of an element, the system read the "direction" as perpendicular to what it was.
Duh.
Dwight Atkinson
Duh.
This is because by default the main direction of the 3D Hatch aligns with the longest side of the element. See attached picture. Slab on left is 5 meters by 4 meters. Slab on right is 3,8 meters by 4 meters (horiz/vert).
Dwight
I knew that.
Dwight Atkinson
Jefferson
Laz,
D*mn! I didn't! Sometimes I'm concentrating so much on the complex things I drive right on by the simplest ones..............Thanx!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
