Amending window attributes to match
If I change some attributes on a particular window like, Pen colours for plan view and elevations, dimension marker text, materials etc
How can I copy all the attributes I have changed into the remainder of my windows with out changing the physical appearance of the window (using eyedropper)
This would apply to any object, walls, columns etc. Thanks
5 REPLIES 5
Ctrl+Shift+T.
But you need to select the things you want to edit first.
That brings up the 'edit selection set' dialogue but how do you use it. I have read the help.
If I have one window that has a blue pen for the main frame in contour and the others are pink pen, how would I change the blue pen window using ctrl+shift+T?
Thanks
Ctrl+Shift+T will only let you change the 2D pen colour and layer of the selected objects.
You can't change object parameters using this.
The eye dropper and syringe tools can transfer parameter settings from one object to one or more other objects but unfortunately you can't pick and choose which parameters to transfer.
All settings (height, width, layer and all parameters) will transfer - unless you have edited the objects GDL parameter list not to transfer the setting.
To change just one or two parameters that are common in all selected objects you have no choice except to select those objects together and change the parameters in the settings.
NOTE: if you select multiple objects with varied pen colours you will see the settings for only the last object selected.
If that pen colour is blue and you want all the others to be blue then nothing will happen.
You have to change to a different pen colour (say green) and then OK this and then back to the settings to change the pen colour to blue.
Or you must deselect the objects that already have the correct pen colour.
Or ensure that the last object you select has the wrong pen colour so that you can change it.
Hope that makes sense.
It has always annoyed me that the parameters don't say "various" when multiple object with different settings are selected.
You can just change the colour to something other than blue, then change it to blue again without hitting o.k. and going back into the settings.
Yes you can to.
Must admit I don't do this very often.
I'm sure it used to be different though at least in the edit selection set dialogue.
I'm sure you had to OK and change again - maybe I am just imagining things.
Thanks for the update Stuart.
