2024-02-13
08:43 PM
2024-02-15
04:42 PM
Hi!
I will try my best to explain the issue with fills I have.
We add fills on top of elevations, for tiles it’s important that the fills (tile size) is layer out logically. By logically I mean that if I have space 24x12, and I use tile that is 24x12, that it will use for that space only one tile instead of two.
so far I tried all different “layout options” from the archicad selection but neither one would fit the tile in the space that is designed for the tile. It’s important for us for the tile to be well layed out so the trades understand it, they would not guess it’s random and would make mistakes.
if the fills aren’t working like this we would have to do all of this manually, and then I could as well just use sketchup for free ..
does anyone have solution for this?
in photo attached the tile is as mentioned 12x24” and the width for the space is 24”, so why it doesn’t show just one tile?? (Layout setting/spread doesn’t help)
2024-02-14 12:33 AM
This is easily achievable:
turn on fill handle display
set fill origin to 'Link to Fill Origin'
drag origin to where you want the fill pattern to start
2024-02-14 01:23 AM
For elements in plan with a cover fill what Scott has shown is the best way to get plans to represent the tile or product layout correct. For elevations I suggest going into the 3D window and using the align 3D command. Make sure that you have the element selected first before selecting the command. Then you can set your setout point for the tiling on the walls, removing the need to overlay 2D fills for tiles on your internal elevations.
2024-02-14 01:40 AM
hi! Thank you for your response! I followed all, including turning on the fill handles which I hadn’t had on. But not working :/// this is what happends when I set it up to origin, and I confirm the tile is 24x12 .. I also tried the other options to layout … still showing 2 tiles instead of just one . how come? 😞
2024-02-14 01:43 AM
I would go into the fill setting and check the grid size that has been set for the fill. One other thing to note which isn't a big thing, you have it set to cut fill, rather than cover fill. May not change things unless you have graphic overrides set up for specific views.
2024-02-14 01:49 AM
The only problem with this is it will affect both sides of the wall.
So if you have a surface with a hatch pattern on the other side of the wall, it will move as well.
Works fine though if you only have a surface that has a hatch pattern on one side of the wall only.
Make sure you have 'vectorial hatching' option turned on in your elevation settings.
It will also affect the texture image (bricks, tiles) that you see in 3D with the Hardware acceleration (OpenGL) engine.
So 3D images will look good as well (but again maybe not on both sides of the wall).
2024-02-14 02:06 AM
True. This is why I always model my wall and floor finishes as separate elements. 🙂
2024-02-14 02:55 AM
thank you for letting me know! I am not as far as graphic overrides yet lol 😄 I looked at the tile setting and this is what I got. Do you see anything unusual that can affect the way the layout is laid?:D
2024-02-14 02:58 AM
YOU ARE MODELING WALL AND FLOOR FINISHES???????? 😭 Omg i hope this is not standard. I still do my elevations old school, aka autocad. I prefer it and it's faster for me (we do visuals externally in another software so I don't mind). But... I still hope that the generic stuff, such as fills and such can be easily figured instead of modeled. I can't believe you are modeling it actually
2024-02-14 03:00 AM
When you want a scaled hatch pattern like tiles, you want the fill to be set as "Scale with Plan"
Then the pattern size should be set to reflect the size of the tile.
