Architectural Model displays differently when hotlinked
LFBIMMAN
Hi All,
I am having an issue where our architectural model looks different when hotlinked in to our structural model.
I have checked story settings, composites, deleting anything far from origin & wall linking but cant seem to make ground on fixing the problem, has anyone experienced this problem before?
The architectural model was made by our sister office that has a lot less experience with ArchiCAD than we do, I didn't know if they have changed a setting that is causing this as I have never come across this before after 8 years of working with ArchiCAD.
Pictures Attached.
Thanks
ā€ƒ
ā€ƒ
ā€ƒā€ƒ
mattsharon
I completely understand your frustration with the architectural model looking different when hotlinked into the structural model. It's certainly puzzling, and having a less experienced ArchiCAD user involved adds another layer to the investigation.
While I can't diagnose the exact issue without more information, here are some steps we can explore together to narrow down the potential causes:
1. Deep Dive into Hotlink Settings:
  • Compare Hotlink Module Manager settings: Double-check that both models share identical settings for Layer Combination Options, Merge by criteria, and Operator Elements. Even minor discrepancies can cause visual differences.
  • Verify Layer Visibility: Ensure all relevant layers are visible in both models and their layer combinations within the Hotlink Manager. Sometimes hidden layers can create unexpected results.
  • Check "Filter by Level" and "Filter by Story" options: Mismatched settings here could lead to missing elements in the hotlinked model.
The bulk of the model looks fine.
It just seems to be those 2 larger skylights.
What is different about those compared to the 2 smaller ones?
Guru
Your storey settings are the same between the hotlink and host file? Though in the hotlink settings, you can set it to retain the original storey heights.
