2004-09-11
12:51 AM
2023-05-26
03:21 PM
Rubia Torres
2004-09-13 11:40 AM
Ignacio wrote:Can't you just Overwrite those composites with composites with the same name in the other file?
This has happened to me before and I have a sense that I had found a workaround but now forgot what it was.
I open the Attribute Manager from the file whose composites need updating, purge unused and delete as necessary, hit 'Apply', the sure-you-want-to-delete-all-this windows comes up, hit 'Delete', everything cool, open my reference file in the Attribute Manager window, command-click the composites I want, hit 'Append', hit 'Apply', the sure-you-want-to-create all-this-stuff window comes up, everything cool, and when I hit 'Create' I get the bug reporter and the crash.
What should I be doing that I am not doing?
[Update: I am now trying creating one composite at a time and it seems to be working. But this is not really the way it should be working, I think.]
2004-09-13 07:50 PM
laszlonagy wrote:Most of the composites are new. The problem seems to be happening only when Attribute Manager needs to 'Create' as opposed to 'Modify'. I have no clue as to what is going on. I am trying one composite at a time, I still get crashes 90% of the time and I can't find a pattern.
2004-09-13 10:19 PM
2004-09-14 12:54 PM
Ignacio wrote:You might want to report this problem to your local reseller along with REP and ATT files.laszlonagy wrote:Most of the composites are new. The problem seems to be happening only when Attribute Manager needs to 'Create' as opposed to 'Modify'. I have no clue as to what is going on. I am trying one composite at a time, I still get crashes 90% of the time and I can't find a pattern.
