Atypical window shape
Hi I'm struggling to design this simple but atypical window. do you have some recommendation how to reach this shape ?
Skärmavbild 2021-09-27 kl. 15.54.59.jpgSkärmavbild 2021-09-27 kl. 15.58.34.jpgIMG_6223.jpg
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
16 REPLIES 16
The trick to get the hole to match the frame is to add a slab that is the overall shape of the window and give it an ID of WALLHOLE.
Then when you save it all as a window object, it will automatically create the correct shaped wall hole from that slab.
Jop You are right I din't get it that I have to be on windows settings.
But unfortunately there is non description how to reach this tape of window 😕
AC 7 - 27 SWE
The first one with no image seems to be in English (2 & 3 are German I believe).
The 4th one, I got an error message when trying to download.
Just select and then press Download button.
It will be added to your Embedded Library.
As I said, I have not used this object but is is all stretchy in elevation and even a preview in plan by the looks.
There seem to be some description in the plan preview for what to do.
There will be a video by the creator @Hmooslechner somewhere in a post here.
I think this is the post with a link to a YouTube video.
https://community.graphisoft.com/t5/Design-forum/Polygonal-freeform-Window-with-inner-freeform-grid/...
Thanks but for now I gave up this solution ... problems with libraries for (sweden version) and it's quite hard to get it how to do properly Skärmavbild 2021-09-28 kl. 11.06.46.jpg
AC 7 - 27 SWE
Thanks, now I understand
AC 7 - 27 SWE
Thanks a lot Barry. Just curios... are you answering this at 2:36 AM in your time zone ? 😅
AC 7 - 27 SWE
No it was 5.36pm here.
In your profile settings there is an option to set the time zone.
My Settings > Preferences > General.
