ā2006-01-12 04:45 AM
ā2006-01-13 05:59 PM
Djordje wrote:Djordje- You and Dwight and a few others sound like the real Archicad pros on this website. I'd appreciate it if you could humor me for a minute and answer the questions in my second post.Ben wrote:This is putting it mildly ...bruceprice wrote:hello! YES
maybe my previous firm was a little backwardsš
ā2006-01-13 06:40 PM
bruceprice wrote:There is a 3D wall accessory that places wall head & sill plates, but most people I know prefer to use 2D wall plates, since they also have to place batt insulation.
If you do a section cut, can you automatically generate wall plates (and other standard wood frame structural details) by specifying 'wood frame' with the wall tool? Or do you have to add these manually every time you draw a wall? And do you do this by 3D modeling the wall plates? Or by 2D drafting them on to the section cut? And if you were to 2D draft lines onto the section cut, can the lines easily be linked to a 3D object so that if the 3D object were moved, the associated lines would automatically move with it? Can you automatically generate labels (i.e. you draw a (customized) wall with the wall tool and then open up the section and it already has cedar shingles, 1/2" plywood, & 2x6 @16" o.c. labeled?)
bruceprice wrote:No. You usually have to draw a heavier polyline to "pop" the building outline.
Finally, regarding lineweights, can the same object have 2 different line weights depending on the context of it's edge? For example. can a cornerboard be automatically programed to have a heavy line at the outer edge of a building and a much lighter line on it's inner edge, adjacent to the clapboard siding?
ā2006-01-13 09:04 PM
TomWaltz wrote:bruceprice wrote:There is a 3D wall accessory that places wall head & sill plates, but most people I know prefer to use 2D wall plates, since they also have to place batt insulation.
Likewise with siding, there are several add-ons that model siding. We just have a 2D profile that we multiply up the side of the building.
All 2D work is completely independent of the 3D elements.
The labels are another story, but generally they call out wall types, door numbers, and other information assigned directly to the 3D elements. They are turned on and off in any section or elevation and do move with their respective elements.
There are all kinds of workarounds to do these in 3D, but sometimes the simple 2D applique works best.
ā2006-01-13 09:35 PM
ā2006-01-13 09:45 PM
ā2006-01-13 09:52 PM
ā2006-01-14 06:56 PM
ME: "Hey, like, don't change now, look at this art I just made."The evils
BOSS: " You Wankadilly! Masons know how to place bricks. You don't have to draw them all!"
ā2006-01-14 08:45 PM
Dave wrote:Did he have a dusty boot print on his butt?
when an architect I hired six month ago demanded his pay and stomped out of the office
Dave
ā2006-01-14 09:23 PM
DwightNah, I think the verbal boot prints prior to that sufficed.
ā2006-01-14 10:41 PM
bruceprice wrote:A big factor you are not bringing into your math there is 'drawing coordination'. Lots of people devote a major part of their professional lives to 'drawing coordination', and then to dealing with the contracting, pricing, site problems that arise from the 'conflicts' they miss.
It sounds like a lot of the detail in your sections and elevations comes from 2D applique. And since this 2D applique is independent of the the 3D elements then [ā¦] it seems like it could almost be easier to work in 2D than to invest a huge amount of time in the 3D model, then create all of the applique and then have to move around all of your applique in the 3D windows everytime you make a change.
