2006-03-12 05:40 PM
2006-04-02 08:53 PM
2006-04-02 09:26 PM
Adalbert wrote:If you cannot show a little courtesy, then be quiet. Just because Ben has a different opinion gives you no right to insult him.
archibeam.
You’re full of it and just sucking up to GS.
YES WE NEED CODES IMPLEMENTED
REVIT is implementing the code – just for an example in the Structural module you have all the possible codes with all the possible options.
2006-04-02 11:34 PM
Adalbert wrote:i'm sure there are a few people who might disagree . . .
archibeam.
2006-04-03 05:29 AM
2006-04-03 01:32 PM
2006-04-03 06:24 PM
Adalbert wrote:Both of the statements not true ... but, it is easier to unload here than to visit a professional?
Adalbert wrote:Which codes?
Adalbert wrote:WHICH codes? If only US, sorry, not enough for the rest of the world.
2006-04-03 06:34 PM
March, wrote:Could not agree more ...
The main subject does seem to be getting re-directed from fixing or improving the basics...
Improving the known & very real construction issues encountered when making simple buildings (slabs, roofs, stairs, pens, materials, etc) would seem to need addressing before trying to sell us more high end features...
2006-04-04 01:23 AM
2006-04-04 08:33 PM
KeesW wrote:One concept Graphisoft should be able to make straight away from their setup is that nobody should be dealing with the object defaults, but extracting the objects from modules where everything (line types, pen weights, materials, 2D and 3D looks, layer, listing data) is set up to match the template (and schedules, and etc.).
the appalling defaults […]I thinks that Graphisoft's defence of its templates is valid.
2006-04-26 05:16 PM
