ā2019-03-31
05:31 PM
ā2023-05-24
08:13 AM
Rubia Torres
Solved! Go to Solution.
ā2020-05-23 08:29 PM
Mike wrote:
Braza wrote:Thanks. Setting to custom or frame= wall thickness makes no difference either.
Ok. Then I'd check frame width inside door settings. It must my set to "Custom" instead of "Fit Wall thickness".
That is what come to my mind for now.
I am an archicad rookie, so it could be one of the hundreds of door settings.
ā2020-05-25 05:30 PM
James B wrote:Thanks James. That did the trick.
The opening takes the Wall thickness where the Anchor is.
Try changing the Anchor, Header to Wall Base instead of Still to.
I didn't catch this one because I model baseboards separately.
So the "Opening Reference" on the Profile Editor is just for the symbolic floor plan display, right?
ā2020-05-26 05:52 AM
James wrote:Sorted, Thanks!
